Gigabyte announces its C500 Panoramic Stealth case
Gigabyte announces its C500 Panoramic Stealth. This new reference offers an aquarium-style design and compatibility with BTF, Project Zero and Stealth motherboards.
C500 Panoramic Stealth: a new case reference for Gigabyte!
Gigabyte C500 Panoramic StealthWith this new reference, Gigabyte offers a case measuring 235 (W) x 430 (D) x 501 (H) mm. Materials include steel, plastic and tempered glass. As can be seen, the front panel and side glass meet without any visible pillar, offering a clear view of the configuration.
Internally, the case is compatible with so-called ” back plug” motherboards. These include MSI Project Zero, Gigabyte Stealth and ASUS BTF. Supported formats include ATX, micro-ATX and mini-ITX.
For the rest of the components, we have :
  • 410 mm for the graphics card, with vertical mounting possible
  • 200 mm for the power supply
  • 176 mm for CPU cooler
By default, the case offers solid ventilation with four aRGB fans fitted as standard. Those mounted on the side of the motherboard benefit from inverted blades for a better visual appearance while offering a good level of performance. However, the case offers six additional slots: 3x on the top and 3x on the bottom. For watercooling, a 360 mm radiator support is included.
A five-port aRGB hub is also available. The various panels feature a tool-free mounting system, while the dust filters are removable. The control panel also features a 10 Gbps USB-C port.
Pricing has yet to be determined, but this model will be available in black and white.
Here’s the Gigabyte product sheet!
