Get a high performance VPN for less than 1€ / month
Limited offer A powerful VPN for less than 1€ / month is possible
Using a VPN is all the rage these days. Obviously we all have in mind the interest of a solution like this for security and privacy issues. But the other side of the coin is always that you have to make concessions when it comes to performance. Ivacy VPN gets around the problem by using split tunneling. A technology that he masters well considering his seniority on the market (Ivacy has been on the market for nearly 10 years). With this method you can “split” the internet traffic to send part of it via an encrypted VPN and another part (less sensitive for example) via a separate tunnel on the open network. Thus, with this innovative option, you can access local and foreign content at the same time without any limits .The settings are easy and allow you to choose which applications to secure and which ones can connect outside VPN.Ivacy VPN The Ivacy offer at 54€ for 5 years ( 0.9€ / month ) also allows to be used on more than 10 devices. And all this with a single account. So obviously, if you want to take advantage of this VPN for streaming, this service will give you access to the entire catalog of 7 major regions: The United States of course but also France, Japan, the United Kingdom, Australia, Germany and Canada.
The change of zone is easy as you can see: But the performance of this service does not stop at Netflix, since you can also enjoy a full unlocking of the entire Disney + catalog Finally, on the P2P side, speed remains the major concern and Ivacy is once again very efficient thanks to specifically optimized protocols. The icing on the cake is the mobile application that allows you to connect simply (in three steps) from an Android or iOS smartphone, but if you want to stay on your PC, Mac or even your Nvidia Shield or Amazon Fire Stick, applications are available!
IVACY VPN mobile On your PC, the installation is even simpler with an automatic setting in 3 steps to optimize security and performance. IVACY VPN PC
Let’s be clear: this VPN is simply magic!
Given the company’s long history and its position as a forerunner in the world of VPN, ivacy’s performance is based on more than 5700 servers ivacy’s VPNs are located in more than 100 cities around the world. All this explains why Ivacy is regularly ranked first in VPN benchmarks for its performance. These results have been praised by its users on TrustPilot, who have given it a rating of 4.8/5. To sum up, the advantages of this VPN are multiple:
  • no logs
  • remarkable performances
  • 256-bit encryption (AES 256)
  • advanced TCP, UDP, L2TP and IKEV protocols
  • malware protection
  • iPv6 and DNS leakage protection
  • ability to use your own DNS server
  • optimization for P2P
Subscribe to Ivacy VPN
The performance of this VPN is top notch
The IVACY Mobile App
