Gee Scorpion : a scorpion gaming chair for $4500 !
If you like completely crazy projects, we have spotted one that surely deserves your attention. Indeed, the Gee Scorpion is one of those things that do not go unnoticed… And for good reason, this game seat takes the shape of a scorpion’s tail with the little paws that go well!
Gee Scorpion: “Scorpion, ready to sting!”
Gee ScorpionClearly this type of chair will be very, very bulky since it has dimensions of 112 (W) x 210 (D) x 210 (H) cm at the most. The weight makes that you will not want to move every six months: 200 kg!
However, keep in mind that this chair also plays the role of a screen holder. The tip of the tail allows for the support of a single 49″ screen or a triple screen of 29″ monitor. Anyway, the maximum weight supported is 24 kg, enough to do. In addition, we have the right to a shelf to put the keyboard and mouse. The latter measures 87 x 32 cm.
Regarding the seat, we learn that the seat is padded with a high-density foam (without giving a figure). As for the covering, we have the right to high quality PU, still according to the data sheet. As for the position, via a remote control, we can manage the inclination of the backrest and seat so that we find ourselves in an almost lying position. Moreover, the remote control will allow you to manage the lighting of the chair.
Finally, as far as the price is concerned, it will cost 598,000 yen, or about 4700 €. And we don’t count the shipping costs, the customs and other taxes related to the import.
Here is the technical data sheet!
