Gamdias offers us its Boreas P1-720, a big double tower
New heatsink from Gamdias which announces an aircooling model in double tower format. This is the Boreas P1-720, a model with two fans and a height of less than 160 mm. It is a model that follows the announcement of the watercooling kits of the brand.
Boreas P1-720 : new heatsink at Gamdias.
Gamdias Boreas P1 720With this cooler, the brand offers a model that seems rather neat. The top of the fan offers black plates screwed with chrome screws, which provides a nice contrast. Similarly, the whole structure is completely black, from the fins to the heatpipes.
Speaking of fins and heatpipes, you should know that this set consists of two cooling towers. These are crossed by a total of seven heatpipes that meet at a nickel-plated copper base. However, the latter is not eccentric, so beware of the impact of the heatsink on the RAM.
For the cooling, we find two fans, the first one in 120 mm, the second in 135 mm. As for their characteristics, here they are:
  • 120 mm:
    • Speed: from 600 rpm to 1750 rpm
    • Air flow: 68.7 CFM
    • Static pressure: 1.65 mmH2O
  • 135 mm :
    • Speed: 800 rpm to 2000 rpm
    • Air flow: 84.2 CFM
    • Static pressure: 1.91 mmH2O
Again, the price is unknown, on the other hand, the dimensions are: 148 (W) x 162 (D) x 157.5 (H) mm.
This way to the Gamdias datasheet!
