GAMDIAS AEOLUS P2: Daisy Chain and ARGB Infinity mirrors
GAMDIAS AEOLUS P2 are high-performance fans. It is an advanced cooling solution with innovative features. There are three editions: ” AEOLUS P2-1203U “, ” AEOLUS P2-1203 ” and ” AEOLUS P2-1201 “. Each fan features a cable-free daisy-chain design for easy cable management. With a 30 mm thick frame, PWM functions and hydraulic bearings, the fan guarantees extreme cooling performance.
gamdias aeolus p2
What do they have that the competition doesn’t?
Every AEOLUS P2 can be connected without the need for multiple cables, thanks to a solid structural design. This creates a unique assembly experience. Daisy-chain multiple fans and connect them to the AEOLUS Box II USB. GAMDIAS ZEUS CAST software lets you fully customize your experience. You can adjust lighting effects, fan speeds and much more.
Different fan blades?
The ” AEOLUS P2-1203U ” and ” AEOLUS P2-1203 ” include three 30 mm thick ARGB fans and three interchangeable fan blades. AEOLUS P2-1201 ” includes one 30 mm ARGB fan and one interchangeable fan blade. The attached fan blades offer a flexible option. It is therefore possible to change the intake airflow without changing the orientation of the fan housing. Each fan is equipped with PWM functions and hydraulic bearings to generate maximum airflow. The whole unit will operate with a minimum of noise and a long service life.
And what about ARGB?
The fan is designed with two aluminum logos in the center. It is embellished with two ARGB strips, and equipped with infinite ARGB mirrors on both sides of the fan housing.
GAMDIAS AEOLUS P2 for more information:
