G413 SE: Logitech keyboard with PBT keys for less than $100!
The Swiss brand Logitech announces two new keyboards with the arrival of the G413 SE and G413 TKL SE models. You will see, these models remain very well positioned and offer small advantages not negligible!
G413 SE: Logitech keyboards in aluminum and PBT!
Logitech G413 SEWith these new models, the brand announces two keyboards, one in the classic format, with 104 keys, the other in TKL, without numeric keypad. Moreover, the small specificity remains their keycaps which are in PBT. Clearly, it is an advantage to have keys that do not shine much or not at all over time unlike ABS in particular.
While we’re at it, let’s also talk about the materials used by Logitech, which puts forward an aluminum faceplate. However, the latter uses a low-carbon aluminum to limit its carbon footprint.
Otherwise, inside, we find touch switches with an accent point at 1.9 mm and a strength of 50 g. Roughly speaking, these are cherry brown with a very slightly more sensitive touch. With this, we do not have an N-Key Rollover but a 6-Key Rollover only. The polling rate is not specified, however, we imagine that it is 1000 Hz. Finally, no RGB, only white lighting.
For the price, the full size model (104 keys) is only $79.99 against $69.99 for the TKL version, without numeric keypad.
Go here and here for Logitech’s technical data sheets!
