FV150: an aquarium-style compartmentalized PC case for Cougar
Cougar announces a new case reference, the FV150 RGB. This is a compartmentalized reference with an aquarium-style design. In short, a model in tune with the times!
FV150 RGB: compartmentalized and aquarium!
This is a rather imposing reference with dimensions of 300 (W) x 415 (D) x 400 (H) mm.
Internally, it will accommodate a maximum of one ATX motherboard. As for the rest of the components, we have :
  • Graphics card: 400 mm
  • CPU cooler : 180 mm
  • Power supply: 210 mm
Out of the box, this case comes with a total of four fans, three of which are mounted on the side of the motherboard, with the last one positioned at the rear. If required, up to ten 120 mm fans can be installed, with three additional slots at the top and bottom of the case. As for watercooling, compatibility with 360 mm radiators is guaranteed at the top.
Last but not least, this case features fan mounting on removable brackets. It also benefits from full dust filtration, while inside we have an aRGB hub for the fans, six to be precise.
All that remains is to find out how much it will cost! However, we do know that the case will be available in white, black and pink.
Here’s the Cougar product sheet!
