Frost Tower 120 : another dual tower fan unit from Thermalright
The Frost Tower 120 is the umpteenth fan to come out of Thermalright ‘s factories, and it’s a new double tower fan in 120 mm. But this time, this model has an eccentric base.
Frost Tower 120: another Thermalright dual tower cooler… But with an off-center base !
Thermalright Frost Tower 120In the program, we find an air-cooler in double tower format. This model is rather compact with dimensions of 125 (W) x 109 (D) x 154 (H) mm without fans. The weight is 755g, without fans.
The radiator itself has two cooling towers each consisting of 45 aluminum fins. Finally, we find a total of six copper heat pipes of 6 mm each. They meet at a nickel-plated C1100 copper base that is eccentric on the side. This allows the cooler not to obstruct the first PCIe slot on the motherboard.
On their side, the ventilation is provided by a duo of TL-C12 Pro-G. Each fan will run up to 1850 rpm ±10%. At full speed, the airflow will rise to 82 CFM when the static pressure reaches 2.1 mmH2O.
Finally, in terms of compatibility, we find the usual support for LGA-2000/1700/1200/115x platforms in Intel. On the AMD side, we have theAM4 andAM5.
As always, no selling price is yet…
Here is the technical data sheet of Thermalright!
