Frost Knight S360 Pro: a powerful pump fan!
Silverstone has announced a new all-in-one water-cooling kit, the Frost Knight S360 Pro, which features a large pump fan. In fact, it features a 120 mm fan, which stands in stark contrast to the fans typically found on AIO pumps. The goal is to effectively cool the components located around the socket, such as the motherboard’s power stages and RAM.
Frost Knight S360 Pro: a 120 mm pump fan!
A professional look for a consumer-grade kit?
Silverstone Frost Knight s360 Pro
With this AIO, Silverstone is offering a kit designed for consumer platforms. Indeed, its socket compatibility highlights support for AMD’s LGA-1851/1700/1200/115x and AM4/AM5 platforms. Furthermore,the AIO features a discreet, all-black design without a RGB lighting. In the center of the fans, we can also see their brass bearing shafts.
In any case, this is a kit with a 360 mm radiator. The radiator features an aluminum construction on one side. On the other side, the thickness is quite standard: 27 mm. However, this setup includes three 120 mm fans capable of operating at up to 3,000 RPM. At full speed, these fans will generate a substantial airflow of 85.99 CFM, as well as a high static pressure of 4.96 mmHâ‚‚O. However, be aware that noise levels are likely to be significant!
Finally, the pump is quite large, measuring 122 x 120 mm, with a height of 79 mm. In terms of speed, it operates from 800 to 3,300 RPM, while the top fan it features offers specifications similar to those mounted on the radiator. Yes, the components around the socket will be effectively cooled, but at what cost?
No price yet:
Of course, Silverstone hasn’t announced a retail price for its kit yet, and it’s a safe bet that the price will be revealed when it goes on sale.
Check out Silverstone’s product page here!
