Four RTX 4060 Ti for MSI too!
Now it’s MSI’s turn to present its RTX 4060 Ti series with four cards, as Asus. The brand presents its Gaming X and Ventus series, at least for now. It is not excluded that Suprim versions will come later.
RTX 4060 Ti: the Gaming X versions!
For now, the Gaming X series represents the highest range of RTX 4060 Ti from MSI. Two versions are offered, the first is equipped with a three-fan heatsink while the second is more compact. Indeed, the radiator, truncated, loses a mill to gain in compactness!
In all cases, Torx Fan 5.0 fans of the latest generation are used. The radiator is based on Tri Frozr 3.0 and Twin Frozr 9 in the case of the model with two fans. Of course, an RGB lighting system is part of the game, as well as the perforated backplate .
The Dual 3X and Dual 2X Black versions!
The Ventus series is much simpler, but also plays the card of a more accessible price. First, we say goodbye to the RGB lighting system. Then, we have the right to old generation fans with Torx Fan 4.0. However, the brand keeps the backplate in order to stiffen the card.
In addition, we find two versions, a Ventus 3X version with an imposing silver fairing. The Ventus 2X Black version is more compact since it loses a fan. It is also more discreet with its completely black shell.
Once again, the frequencies will only be known at the end of May, at the time of the launch. As a reminder, the official prices are 539 € for the 4060 Ti 16 GB against 439 € for the 8 GB version. Finally, the non-Ti model will land at 335 €.
Here are the technical data sheets of MSI !
