FF04: an ITX case specially designed for ASUS RTX ProArt!
In China, we can find the best as well as the worst. Fortunately, today we’re going to tell you about the best, with an apparently unofficial case. It’s perfectly suited to ASUS ProArt graphics cards!
FF04: a custom-made case for ASUS ProArt cards!
FF04 ProArt Xikii Industry
The exact dimensions of the case are not known. However, we do know that it offers a volume of 9.8l. This inevitably makes it a compact reference that will only be suitable for ITX motherboards.
However, its special feature is that it has been specially designed to accommodate an ASUS ProArt graphics card. Once installed, the card will be open-air, with the fans directly out in the open. Clearly, this greatly facilitates ventilation, but also allows all manner of dust to creep into the heatsink.
But the best thing about this case is that its casing perfectly matches the shape of the graphics card’s fairing. This demonstrates a certain quality of finish.
For the rest, the case arrives in the same hues as the brand’s famous series of graphics cards. FF04″ copper branding is found on the side, while a “Xikii Industry” logo is molded onto the front. Otherwise, connectivity features four USB-A and one USB-C. The power button is also copper-colored.
The first batch of cases is already sold out, despite an equivalent price of €458 (3,599 yuan). Shipments are scheduled between April 15 and 30. Finally, an accessory (billed at ~23 €) enabling the installation of an external watercooling system will be offered at a later date.
