EKWB launches waterblocks for NVIDIA RTX A5500
EKWB announces new waterblocks for graphics cards signed NVIDIA. However, it is a professional series since EK attacks this time the RTX A5500 of the green. As a result, we have two different blocks corresponding to the environment in which they will be installed.
RTX A5500: waterblocks signed EKWB!
With its new blocks, EKWB announces full cover models that will cover the entire PCB of the card. The GPU, the memory and the power supply stages will be perfectly cooled. Note also the visual, very industrial blocks with many visible screws. But here we are dealing with the professional sector, we are looking for efficiency before design… No more acrylic upper parts with RGB.
Moreover, depending on the model, the terminal will not be positioned in the same place. On the rack version, the G1/4″ threads migrate to the rear while being oriented at 45°. The goal is to limit the height as much as possible in order to fit into servers… racks. Otherwise, on the nickel + stainless steel model, they are positioned on the top, still oriented at 45°.
As far as compatibility is concerned, it’s simple, they will only be installed on an NVIDIA RTX A5500. Here, there are no differences in terms of PCBs. Moreover, the price stings a little since it is displayed at 280 € in its nickel + stainless steel version against 300 € in a rack with terminal at the back.
Here and there the technical data sheets of EKWB!
