EKWB announces a waterblock for the RTX 6000 Ada!
Heading for Slovenia, EKWB announces a new waterblock. This time, the company isn’t offering a block for consumer graphics cards, but for a pro card… And what a card it is! In fact, it’s a heatsink designed for the RTX 6000 Ada, a $6800 model we’ve already talked about already talked about !
RTX 6000 Ada: a waterblock for NVIDIA’s pro card!
waterblock EKWB RTX 6000 AdaAs you can see, the look of the block is sober, with a stainless steel top. Otherwise, the base is in nickel-plated electrolytic copper. Naturally, critical components such as the GPU, memory and power supply stages will be cooled.
Given the professional market, this is a terminal off the beaten track. Here, inputs/outputs are oriented at 45°, limiting height impact in server/workstation-type machines… It’s also compatible with the EK-Pro QDC system.
Last but not least, the backplate is not just for show. The backplate helps to passively dissipate the areas around the board’s power supply stages.
All that remains is to mention the price, which is starting to sting. We’re talking €285.90 for this model!
Here’s the EKWB datasheet!
