The EKWB brand announces new watercooling radiators. These are part of the EK-Pro Radiator series, and they are imposing models. In fact, the company is putting forward references measuring 480 mm and 360 mm!
EK-Pro Radiator: 480 mm and 360 mm radiators announced!
The brand is announcing 480 mm and 360 mm radiators. This means you’ll be able to install up to 8 and 6 fans in push/pull configurations. However, you’ll need a spacious case, as each radiator is 45 mm thick. Likewise, a 480 mm radiator won’t fit into every case.
The construction is based on copper for the fins and internal channels. Otherwise, brass is used for the patch bays, while stainless steel is used for the side panels. Finally, nickel-plated brass caps are used for unused ports.
By the way, EKWB offers a completely black finish here. The radiators feature a total of four G1/4″ threads. As for fin density, the Slovenian brand advertises 18 FPI, which it claims provides a good level of performance even with slow-running fans. This keeps the machine cool and quiet.
As for prices, the 360 mm model costs around €140, compared with €150 for the 480 mm model.
Click here and here to see the EKWB product sheets!
