Last June, EKWB launched a series of all-in-one watercooling kits called EK-Nucleus. At that time, we didn’t know the prices, until today. Indeed, the kits are displayed on the brand’s store for pre-order.
EK-Nucleus: prices are now known!
With this Nucleus series, it is important to know that two versions are proposed. Indeed, EK offers the Lux versions with a simple RGB lighting on the pump. These come in three radiator sizes: 120 mm, 240 mm and 360 mm. Next to that, we have the Vision series that incorporates a display on the pump. However, there is less variety regarding the radiator size: 240 mm and 360 mm.
Of course, an RGB lighting is present at the level of the fans which, by the way, are Vardar 120. They have a PWM power supply and work up to 2200 RPM. However, the manufacturer’s data sheets do not mention the flow or the static pressure generated.
Of course, the models equipped with a screen, know that you will be able to display various information related to the system. Of course, it will be possible to display custom images, etc..
In short, for the price, we have a series rather affordable given the integration of an IPS LCD screen of 2.1″. It will be necessary to count 233,18 € the model in 360 mm against 204,02 € for the 2x 120 mm. Finally, the Lux models (with RGB lighting on the pump) cost between 92.24 € in 120 mm and 155.42 € in 360 mm.
Here are the technical data sheets of EKWB !
