Eiswolf CLC Series: Alphacool’s AIO GPU arrives for RTX 3080/3090
On its side, Alphacool announces the arrival of new all-in-one watercooling kits for GPUs. This time, the brand extends the compatibility of its Eiswolf CLC Series to the RTX 3080 and RTX 3090 from Asus and MSI!
Eiswolf CLC Series : RTX 3080/3090 from MSI and Asus now supported !
Alphacool Eiswolf 2
The kit pictured is for the RTX 3000 Founders Edition
For the time being, the recipe remains the same as with the first models of the series. Alpahcool is an AIO type loop for cooling the graphics card. This loop consists of a radiator, pipes and a waterblock. It should also be noted that the tubes have a quick coupling system. It will therefore be possible to couple this kit to an AIO CPU of the brand.
In detail, for the radiator, we find a model type NexXxos ST30 in 360 mm. Its advantage is to align a construction entirely in copper for better heat dissipation. The latter also embeds a trio of Aurora Rise fans in 120 mm. These mills will rotate from 0 RPM to 2500 RPM and will generate a static pressure of 3.17 mmH2O and an airflow of 119.8 m3/h. Finally, a DC-LT2 pump will circulate the liquid inside the loop.
Finally, we finish with the waterblock made of nickel-plated copper and plexiglass. Again, we find a set intended to cool the GPU, the memory and the power supply stages of the cards.
Regarding compatibility, these Eiswolf CLC Series will be able to mount on the RTX 3080, RTX 3080 Ti and RTX 3090 from MSI and Asus. This concerns the Strix, Strix LC (3080 Ti) and Ventus 3X series. But first, it will cost 244.09 € to afford one of these AIO GPU.
Here and there are the technical data sheets of Alphacool!
