DuoFace Pro: choose the style of your Cougar case!
A new case from Cougar Gaming: the DuoFace Pro. This model comes with two different front panels. The aim? Choose your own case style.
DuoFace Pro: an interchangeable front panel for Cougar’s case!
Cougar DuoFace Pro
This case comes in two colors: white and black. However, two different front panels are supplied. You can choose maximum airflow with a perforated front panel. For added style, a glass front panel is also included.
Otherwise, this is a fairly classic case. This is a mid-tower reference that can accommodate a motherboard in E-ATX format. The rest of the components are not outdone, with a length of 39 cm for the graphics card and 190 mm for a cooler.
In terms of dimensions, this translates into 240 (W) x 465 (D) x 496 (H) mm.
Powerful ventilation is provided by nine 120 mm fans. As for watercooling, compatibility with 360 mm radiators is guaranteed on both the front and the top.
Of course, RGB is present, and to help centralize all this little world, a hub is also present. What’s more, the top part can be removed to simplify assembly. Finally, there’s a graphics card support and three vertical expansion slots!
As for price, this version retails for around €129.99 on the brand’s online store.
Here’s the Cougar product sheet!
