Initially presented during the Computex, the Divider 200 is officially announced. Thermaltake lifts the veil on its compact case capable of hosting micro-ATX motherboards. Moreover, two colors are available.
Divider 200: a compact case for micro-ATX motherboards!
With this new model, Thermaltake offers us a case measuring 333.2 (W) x 425.7 (D) x 364.7 (H) mm. For the weight, we are under the 10 kg mark with 9.01 kg on the scale. So it should not be too difficult to handle.
Inside, we find a horizontal motherboard tray that can accommodate micro-ATX, mini-DTX and mini-ITX cards. We should also mention that five expansion slots are also present. For storage, there is plenty to do with the possibility of installing three 2.5″ units and three others in 3.5″ or simply six SSD/HDD 2.5″.
The rest of the components have :
- 200 mm for the power supply (ATX), 180 mm with fan at the bottom
- 185 mm height for the CPU cooler
- 280/240 mm for a watercooling radiator on the front or on the side
- 340 mm for the graphics card, 310 mm with front mounted heatsink
Of course, given the layout of the motherboard tray, the graphics card will be installed vertically. This leaves the user free to admire his hardware running!
Finally, the Divider 200 comes with a 200×30 mm fan on the front and a second 120 x 25 mm fan on the back. Of course, this 200 mm mill can be removed in favor of two 120/140 mm fans on the front, and the same on the side. At the bottom, two 120 mm models will also go! In short, we can integrate up to seven fans!
This way to the Thermaltake datasheet!
