DeepCool unveils its Spartacus 360 AIO!
DeepCool announces the Spartacus 360. This is DeepCool’s new spearhead in liquid cooling. It features a customizable screen on top of the pump, with AI-enhanced software for fan management.
Spartacus 360: a new spearhead for the Chinese brand!
DeepCool Spartacus 360With this kit, the brand announces a new 360 mm reference that features a removable screen on its pump. The screen is held in place by a magnet system and connected via pogo pins. In any case, this model boasts a 3.4″ diagonal, all with 480×480 resolution and a 30 Hz frequency.
The pump (a sixth-generation model), for its part, features offset mounting for LGA-1851 processors. The aim is to refocus the pump on the CPU hot spot on this platform. Other features include operating speeds of up to 3400 rpm and support for modern LGA-1851/1700 and AM4/AM5 sockets .
Ventilation is provided by three 120 mm mills running from 500 to 2500 rpm. Airflow is 79.89 CFM, while static pressure rises to 3.30 mmAq. It blows pretty hard!
For the radiator, the brand opts for an aluminum block 27 mm thick. The radiator features a neat finish with square edges and rivet-free sides, while the brand’s anti-leakage system is still present.
The kit will be managed by a dedicated controller with a single connector for screen and pump management. The whole package is also supported by DeepCreative software, which embeds AIO-driven features to determine the best ventilation profile.
The Spartacus kit is priced at $245 and comes with a five-year warranty.
Click here for DeepCool’s product sheet!
