DeepCool launches its AIO LS520 SE and LS720 SE!
DeepCool launches two new watercooling kits on the market with its LS SE series. It comes in two models, the LS520 SE and LS720 SE, 240 mm and 360 mm kits respectively!
LS520 SE and LS720 SE launched by DeepCool!
DeepCool LS720 SeWith these new kits, the brand is actually launching ” restyled ” AIOs . Indeed, the base remains the same since they are built around a fourth generation in-house pump. The radiator is still made of aluminum and is 27 mm thick, as on the previous series. Finally, the ventilation is provided by two or three fans in 120 mm RGB.
On the characteristics side, we know that the pump works up to 3100 RPM ±10%. Otherwise, we move quickly to the fans, which operate from 500 RPM to 2250 RPM. Via a low noise adapter, we can limit their speed to 1600 RPM maximum. In their basic configuration, the air flow will reach 85.85 CFM and the static pressure will rise to 3.27 mmAq.
DeepCool LS520 Se
The kits will be compatible with AM5/AM4 and LGA-1700 and older sockets.
The official prices are rather aggressive with a 240mm version listed at €104.99 versus €119.99 for the 360mm. Note that at these prices, we have a neat design based on infinite depth effect lighting on top of the pump!
Here are the DeepCool technical data sheets!
