DeepCool Announces CH170 Digital, a Vertical ITX Case
From DeepCool, we can look forward to a new case with the CH170 Digital. It’s a small reference in mini-ITX format with a small digital display. A really nice little box!
CH170 Digital: a really nice little box!
DeepCool CH170 Digital 1With this new case, the brand is offering us a sober reference that relies on mesh to maximise cooling performance. It’s also a model that adopts a vertical design, which is reflected in its dimensions: 200 (W) x 250 (D) x 380 (H) mm. And because it ‘s an ITX case, it weighs just 3.4 kg.
Otherwise, internally, there’s plenty of space to accommodate a 305mm graphics card in three slots with an SFX power supply. Yes, this case is also compatible with 14 cm deep ATX blocks. However, this will require 230 mm long GPUs to be fitted. Finally, on the cooling side, with 172 mm of air cooling, you can indulge yourself or install a 240 mm water cooling radiator.
DeepCool CH170 Digital 2
As for ventilation, this reference will accommodate up to six 120 mm fans. These are distributed across the top (x1), rear (x2), bottom (x1) and side (x2).
Finally, there’s the digital display at the bottom of the case. This displays the CPU and GPU temperatures, as well as the frequencies and percentage of use of these components. Finally, a wattmeter measures power consumption.
In the end, the bill won’t even be that high, coming in at just ~€80.
Here’s the DeepCool product sheet!
