Jonsbo announces the arrival of a new series of cases with its D31. In total, we find a total of eight new models. Some of them have an 8″ screen, some have a mesh front and some have nothing at all.
D31: compact Jonsbo cases with an 8″ LCD screen!
In the program, we find necessarily a set of cases with a sober and pure design. Nevertheless, the brand integrates an 8″ screen in some models, a screen displaying a resolution of 1280 x 800 pixels. From what we can see, this screen is used to display data related to your configuration or .gif for example.
Otherwise, we have a compact case with dimensions of 205 (W) x 452 (D) x 363 (H) mm. The weight is 6.5 kg, rather light.
Inside, we will have room for a mini-ITX, mini-DTX and micro-ATX motherboard.
Otherwise, the rest of the components have 168 mm for the CPU cooler. As for the graphics card, we have from 300 mm to 400 mm depending on the size of your power supply. Finally, the power supply can measure up to 220 mm, of course, be careful since its size will impact that of the graphics card. Especially since we can adjust the height of its location on four levels. On the storage side, we have two 2.5″ slots in addition to a third in 3.5″.
The cooling part shows 3×120/2×140 mm at the top and bottom in addition to 1×120 mm at the back.
For the watercooling, unlike the D30, we have a 360 mm radiator support at the top in addition to the 240/360 mm at the bottom and the small 120 mm at the back.
Finally, there are no less than eight versions of the case. We have models with a solid front in black and white and those with mesh front. And on each variant, add the possibility of having the LCD screen or not!
Unfortunately, the big question concerns the sales price, which is still not known in our countries. But to get an idea, some Chinese comparators the price is between HK$690 and HK$699, that is to say between €84.87 and €85.97 after gross conversion with the current rates. Note also that this is for the white version with full screen and front. The white mesh version is HK$499, or €61.37.
Here are the technical data sheets of Jonsbo!
