CX600M Trio: a compartmentalised micro-ATX case from Antec
A new case from Antec, offering a new reference in micro-ATX format with a compartmentalized design. The brand unveils its CX600M Trio aRGB, a reference with three tempered glass panels for a clear view of your configuration’s innards.
CX600M Trio: compact and compartmentalized!
Antec CX600M TrioAntec’s compact case measures 290 (W) x 436 (D) x 370 (H) mm. We’re dealing with a reference that will only be able to accommodate motherboards in micro-ATX and mini-ITX format. However, there’s plenty of room for a 410 mm-long graphics card and a 160 mm-high CPU cooling unit. The power supply will be 240 mm deep.
This is a compartmentalized case, meaning that the motherboard and graphics card are housed on one side. The power supply and storage units (1x 3.5″/2x 2.5″) are on the other.
In terms of ventilation, this model features six 120mm fan slots. Two are on the side of the motherboard, three on the bottom and one on the rear. By default, the CX600M Trio offers three 120 mm fans. As for watercooling, we’ll retain the 360 mm radiator support at the bottom, as opposed to 240/280 mm on the side.
Price-wise, this is not a particularly expensive model, as it is advertised at €109/£89.99. Three glass panels provide a clear view of the configuration!
Click here for the Antec product sheet!
