CX200M RGB Elite: a µATX case from Antec!
The Antec brand launches a new case reference on the market, the CX200M RGB Elite. It’s a truly compact case designed for µATX motherboards.
CX200M: a compact case with an aquarium look!
Antec CX200M
With this case, Antec is aiming for compactness, with a model measuring 210 (W) x 350 (D) x 392 (H) mm. It weighs in at just 4.43 kg.
Of course, with such dimensions, you can’t put just anything inside. The motherboard must be in µATX or mini-ITX format. As for the other components :
  • Graphics card: 330 mm
  • CPU fan: 164 mm
  • Power supply: 185 mm
Antec CX200M
For storage, we have a cage that can accommodate two 3.5″ hard disks or one hard disk and one SSD. Alternatively, a small additional board located behind the motherboard tray is available for mounting an SSD.
As for ventilation, you’ll have to make do with five 120 mm slots: 2x on the power supply cover, 2x on the top and 1x on the rear. Fortunately, all fans are supplied as standard. However, Antec makes no mention of watercooling compatibility.
The price is currently unknown, but in view of what’s announced here, it shouldn’t go very high!
Here’s the Antec product sheet!
