Cougar Announces MX330-G Pro Case with 5.25″ Bay
New PC case to see from Cougar with the MX330-G Pro. It is a medium tower format case with a mesh front panel. However, it is distinguished by the presence of a 5.25″ bay, something rare these days!
MX330-G Pro: two 5.25″ bays for the Cougar case!
Cougar MX330G-ProWith this new case, the Cougar brand offers a reference measuring 209 (W) x 475 (D) x 495 (H) mm. The choice of materials is steel, but also tempered glass and mesh for the front panel.
Inside, we have enough space to mount an ATX motherboard. For the rest of the components, we will retain 385 mm in length for the GPU, 160 mm in height for the CPU fan and 200 mm in depth for the power supply.
As for the storage, there are a total of three 2.5″ boards as well as an HDD cage with two 3.5″ slots. Finally, at the front, a 5.25″ bay is present, allowing the mounting of a Blue-Ray player for example.
Cougar MX330G-Pro
The case comes with a single fan mounted at the back. If desired, we can add up to six mills in 120 mm against five in 140 mm. For watercooling, the radiator support goes up to 280/360 mm at the front and at the top, paying attention to the thickness.
For the moment, no price is known.
Here is the Cougar’s technical sheet !
