Corsair offers its Vengeance a8100 and i8100 pre-assembled PCs!
Corsair has announced two new high-end pre-assembled machines. Indeed, with its a8100 and i8100, the brand puts forward configurations based on Ryzen 9 7950X or Core i9 13900KS! In short, PCs focused on performance, ideal for gamers, professionals, or creators!
a8100 and i8100: a big common base!
Corsair Vengeance a8100 i8100
In order to propose its PCs, the brand opts for home-made components… At the same time, Corsair offers a varied catalog, it would be a shame not to pick from it.
For the sake of it, the case in charge of hosting all this beauty is none other than a Vengeance 5000T, an imposing model, but also stylish. With its look straight from the old Graphite series, it also has 160 RGB diodes that can be controlled with the brand’s software. Otherwise, the cooling is entrusted to a H150i Elite Capellix offering good performance.
Otherwise, the configuration itself will have a total of 64 GB (2×32 GB) of DDR5. As memory, Corsair selects its Dominator Platinum RAM that runs at 5600 MT/s. For storage, we find two SSD M.2 in PCIe 4.0 x4, each offering a capacity of 2 TB. Finally, the power supply is entrusted to a large 1000W block.
At the same time, it takes what it takes to power the big RTX 4090 that we find in both cases. And on the CPU side, the brand doesn’t do anything fancy either. We have a Ryzen 9 7950X for the AMD machine and a Core i9 13900KS for the Intel version. All of this on X670/Z790 motherboards respectively.
Of course, the prices are not cheap since they are $4599.99!
Here and there the technical data sheets of Corsair !
