Corsair announces its Frame 4000D LCD RS aRGB enclosure
From Corsair, we learn that the brand is launching a new version of its Frame 4000D case. Today’s new version features a Xeneon Edge screen on the side of the case. This new case takes the original Frame 4000D chassis, but adds a screen… So you’ll pay more, but you’ll also have more customization options!
Frame 4000D LCD RS aRGB: a version with a large side screen!
Corsair Frame 4000D LCD RS ARGBThis new case is based on the chassis of the original Frame 4000D. The dimensions remain unchanged at 239 (W) x 490 (D) x 486 (H) mm. Component compatibility still features ATX motherboard support, with the possibility of mounting BTF models. Otherwise, we have 170 mm of free space for the CPU cooler, 220 mm for the power supply and 420 mm for the graphics card, which also benefits from a dedicated support.
Ventilation can be quite substantial, with thirteen fan slots in the 120 mm version and seven in the 140 mm version. For watercooling, 280/360 mm radiators can be installed at the top, front or side of the motherboard. Last but not least, Infinirail rails are available.
But the most important addition to this case is the Xeneon Edge display integrated into the side panel. It connects via HDMI or DisplayPort to USB-C. As a reminder, this is a screen offering a high resolution of 2560×1440, all via a touch-sensitive AHVA panel. This display will enable you to keep an eye on your PC’ s temperatures, for example. It can also act as a secondary Windows screen, etc.
It’s just that the price tag goes up, as this model usually retails for around €100 to €120. Here, the first Amazon.co.uk listing shows a price of €343.32! Otherwise, Corsair will be offering an upgrade kit with a side panel that will allow integration of said Xeneon Edge screen.
Here’s Corsair’s product sheet!
