Cooling X: a pre-assembled, water-cooled PC by CM for €7,000!
Cooler Master presents its latest machine, the Cooling X. This is a pre-assembled PC with a muscular configuration. It’s based on a Ryzen 7000 and an RTX 4080. However, its watercooling integration is perfectly interesting and quite unusual!
Cooling X: an original water-cooled war machine with a hefty price tag!
Cooler Master Cooling X
With this pre-assembled PC, Cooler Master offers us a high-performance PC. It’s based on one of AMD’s finest processors, the Ryzen 9 7950X3D, a 16c/32t model. This is backed up by 64 GB of DDR5 RAM running at 5600 MT/s, while the graphics card is an RTX 4080. Of course, storage is provided by an SSD, but in PCIe 4.0, and capacity rises to 4TB. Finally, a V850 Gold SFX block powers the whole, while the visuals showcase an MSI B650I Edge motherboard.
When it comes to cooling, the brand doesn’t mess around and installs a watercooling system on all its components… Well, the CPU and graphics card. However, if a single 240 mm radiator is responsible for dissipating the config’s watts, the side panels also play a role. The internal loop is connected to the side doors, which passively dissipate the heat.
Now for the rather contained dimensions of 148 (W) x 26.2 (D) x 31.7 (H) mm. As for the price, the reported invoice is €6,999.
Here’s the Cooler Master product sheet!
