Cooler Master unveils its Hyper 212 Halo Edition!
Cooler Master launches a brand new CPU heatsink with its Hyper 212 Halo Edition. These are entry-level heatsinks, available in black or white. Of course, we find an RGB fan coupled with a neat heatsink.
Hyper 212 Halo Edition, the return of the Hyper 212 at Cooler Master!
Cooler Master Hyper 212 Halo EditionThe Hyper 212 from Cooler Master remains one of their flagship products. Indeed, it has been declined with all the sauces: with RGB, without, in push/pull, etc. This time, it comes back with a nice finish and a new lighted fan.
Indeed, the base of the radiator does not evolve since we always find a fairly small heatsink. It measures 124 (W) x 73 (D) x 154 (H) mm, enough to fit into almost any case on the market. The heatsink still has four 6 mm copper heat pipes that come into direct contact with the CPU.
Regarding the ventilation, we have the right to a MF120 Halo², a new model. The latter benefits from a PWM power supply and will operate from 650 rpm to 2050 rpm. The air flow 51.88 CFM and a static pressure of 2.89 mmH2O.
Of course, we find a nice finish with heatpipes and fins in black. Also, the upper part is worked with a cover masking the heatpipes. It has stripes and a Cooler Master logo in black.
For the price, the brand announces its heatsink at around 38€ although it is found on Amazon for around 50€.
