Cooler Master launches its MasterLiquid Ion 360 in white
Cooler Master offers us a new all-in-one watercooling kit with the white MasterLiquid Ion 360. Indeed, the black version has been out for a while, but there was no white version yet… Now it’s here.
MasterLiquid Ion 360: a new white version!
Cooler Master MasterLiquid Ion 360Basically, this white version of Cooler Master’s kit is unchanged. The 360 mm AIO is still equipped with a display on its pump. The latter, you know the drill, can be used to display system monitoring data or customization elements (.gif, .jpeg, etc.).
There’s also a standard 27mm-thick aluminum radiator. This is topped by three PWM-powered 120 mm fans. They will operate at up to 2,400 rpm to generate an airflow of 75.2 CFM and a static pressure of 3.63 mmH2O at their maximum.
The pump will be installed on mainstream Intel and AMD platforms. As for speed, count on some 3,000 rpm for this model.
All that remains is to find out the exact retail price of this model, which should be similar to that of the black version… With a 10 €/$ surcharge for the white version, if necessary.
Here’s the Cooler Master product sheet!
