Cooler Master introduces the Hyper 411 Nano
New CPU heatsink with the Hyper 411 Nano. This new reference will occupy Cooler Master’s entry-level sector, as we can guess from its format. In fact, it’s a 92 mm single-tower cooler with four heat pipes!
Hyper 411 Nano: an ultra-compact model!
Cooler Master Hyper 411 Nano
The least we can say is that this new Cooler Master model doesn’t take up much space. With dimensions of 102 (W) x 85 (D) x 136 (H) mm, it will fit just about anywhere.
The radiator itself is nothing out of the ordinary, with a total of four 6 mm diameter copper heat pipes. These will come into direct contact with the processor, typical of entry-level models. However, the aluminum fins boast an attractive black finish.
Ventilation is provided by a 92 mm fan. This will operate from 650 to 2500 rpm. However, if these speeds seem high, bear in mind that the smaller the fans, the faster they have to blow to manage airflow and correct static pressure. Incidentally, here, these values are 45.14 CFM for airflow and 3.25 mmH2O for static pressure.
Last but not least, compatibility with mainstream Intel and AMD sockets! Availability has been announced, but we can’t find it yet… While stocks last. An aRGB version is planned for the first quarter of 2025.
Here’s the Cooler Master product sheet!
