Cooler Master declines its MasterBox Q300L in white!
Cooler Master announces a new variation of its small MasterBox Q300L case. This model is now available in white and offers a modular control panel. In short, a model to build a nice little configuration!
MasterBox Q300L : here is the white version !
Cooler Master Masterbox Q300LWith this new version, we find a compact case measuring 230 (W) x 387 (D) x 381 (H) mm. With these dimensions, clearly, we will not be able to install large configurations inside. Moreover, this model is designed to accommodate a micro-ATX motherboard. The same goes for the graphics card, don’t be too greedy since a GPU of 360 mm max can fit. So with fans or a radiator in front, it reduces. Otherwise, we have a pretty standard space for the CPU fan, which has 159mm of height.
Regarding the ventilation, we find a total of six slots for fans. Two 120/140 mm are present at the front against two 120 mm at the top and one 120 mm slot at the back and bottom. Obviously, for watercooling it limits, since radiators of 120 mm or 240 mm max are supported.
Finally, there is a PS2 ATX power supply slot at the bottom and three storage slots: 1x 3.5″ and 2x 2.5″. The filtration is integral and is provided by very nice geometrically shaped filters. Finally, the next control panel can be repositioned via six dedicated slots.
Currently, the estimated price would be $65 including VAT with an availability for January 27th!
Here is the technical data sheet of the black model!
