Cooler Master also presents its AIO G11 with dual pumps
In addition to its huge V8 3VC cooler and 1100W passive power supply, Cooler Master is also presenting a new AIO, the G11. These announcements aren’t coming out of the blue, they’re being made at CES, which opens tomorrow.
G11, a Cooler Master AIO equipped with dual dual-chamber pumps!
Cooler Master G11Cooler Master announces a new AIO. It has a sober design, with a white shell and a few markings on the pump block. If you don’t like it, you can customize it using 3D printing. Otherwise, it features a few RGB borders – why not?
What interests us here, however, is the pump technology, since it’s actually a double pump in a double chamber. The brand claims that the latter benefits from enhanced performance via increased pressure. However, this system is nothing new: with its SR Pro kits, In Win also offered AIOs benefiting from a similar system.
Finally, for heat dissipation, we find a 360 mm radiator topped by three 120 mm Mobius fans. Obviously, we can also count on a connection mode that reduces the number of cables during assembly… Why not?
In any case, we’ll keep in mind that the kit will be presented at CES. As for dissipation capacity, the brand mentions 300W!
