[Computex] An RTX 4070 Super Blower by Jensen Huang
As you know, Computex is THE event for all hardware enthusiasts. It’s also an opportunity for brands to make a splash by unveiling new projects and prototypes. This is particularly true of PNY, whose stand features a small-format custom machine and a customized RTX 4070 Super Blower. Clearly, the card caused quite a stir, as NVIDIA CEO Jensen Huang signed it!
RTX 4070 Super Blower: signed by NVIDIA’s CEO himself!
Computex PNY RTX 4070 Super Blower
PNY has done things right with this card, even if it’s still equipped with a vulgar blower. In fact, where this type of solution is intended to be as cheap as possible in order to save as much as possible, the brand uses a metal fairing instead of a plastic one. What’s more, the fairing is painted in the same shade of green as the NVIDIA logo.
Anyway, Jensen Huang, who happened to be passing by, greatly appreciated the card and signed it with his own hand. The hull reads ” Jensen Huang was here, June 4 2024 “. The same goes for the mini-machine, where he affixed his signature to the front of the Fractal Design Terra, the configuration’s housing.
As for the board itself, after discussions with TechpowerUp, PNY indicated that it was considering a production run of 7,000 units.
