[Computex 2023] TH V2/TH V2 Ultra AIO from Thermaltake
At Computex, Thermaltake took the opportunity to unveil new AIO-type watercooling kits. The company unveiled its TH V2, a series with infinite depth effect lighting. On the other hand, we have the TH V2 Ultra, a series of kits featuring a display on the pump cover!
TH V2 & TH V2 Ultra: kits with screen, without screen and in all sizes!
Thermaltake TH V2 aRGBWith the TH V2, the brand offers us a series that comes in every conceivable format. In fact, these AIOs are available with 120 mm, 240 mm, 280 mm, 360 mm and 420 mm radiators. The pump features lighting with an infinite depth effect, while the radiator is neatly finished with square edges. As for ventilation, TT announces the presence of CT120/CT140 mills, operating at 2000 rpm and 1800 rpm respectively.
Thermaltake TH V2 Ultra aRGB
Alongside these, we find the Ultra versions based on the same concept. The design remains essentially the same, and the kits feature the same fans. On the other hand, there will be no 120 mm radiator. The other major difference is the presence of a 2.1″ LCD display. All that remains is to find out its resolution and the functionalities it supports… Although we suspect that it will be used for PC monitoring, as well as for displaying at least .jpeg files.
As for availability, we know that the TH V2 Ultra will be available this year, from the third quarter. For non-ultra versions, it’s hard to say, but TT promises aggressive pricing.
