Zalman has added a new heatsink to its current range of aircooling heatsinks: the CNPS14X Duo Black. This new reference comes in a compact double-tower format, all in a style that’s easy to forget in a PC!
CNPS14X Duo: a double-tower heatsink !
In terms of dimensions, this cooler measures 126 (W) x 135 (D) x 159 (H) mm. As for its weight, it weighs in at 1.16 kg, not the biggest or heaviest.
Naturally, it’s a double-tower heatsink, featuring a double stack of aluminum fins. Each of these is crossed by a total of six 6 mm copper heat pipes meeting at a nickel-plated copper base.
Ventilation is provided by two 120 mm mills operating at up to 2000 rpm. At full speed, they will generate an airflow of 69.12 CFM, while static pressure will reach 2.01 mmH2O.
As for socket compatibility, this heatsink can be mounted on mainstream LGA-1700/1200/115X and AM5/4/3 sockets .
For the moment, no price, however, Zalman announces support for TDPs up to 270W, which is significant, as much as a 240 mm AIO.
Click here for Zalman’s product sheet!
