Chieftec announces two Vita PSUs
Chieftec announces two new power supplies. These are the Vita series, rational solutions: functional and not overpriced. This is even reflected in the power ratings, which are far from extravagant!
Vita: Chieftec 750W and 850W power supplies!
Chieftec Vita seriesWith these power supplies, the brand is offering 750W and 850W power supplies. This is a privileged sector for those wishing to assemble configurations that are already quite powerful. In terms of efficiency, the 80 certification guarantees 92% efficiency at 50% load.
Here, cable management is non-modular in order to reduce purchase costs. On the other hand, if the connectors don’t allow an RTX 40 to be plugged in by default. Indeed, the 12VHPW or 12V-2×6 is absent, so you’ll have to turn to the adapter supplied with the card. Otherwise, in PCIe, there are two 6 2-pin connectors.
Otherwise, cooling is provided by a 120 mm fan with an FDB-type bearing. Obviously, no semi-passive operating mount, but it is claimed to be silent.
Finally, we can count on compact power supplies with a depth of 14 cm.
No price yet.
Here are the Chieftec product sheets!
