CH510: a sober and refined DeepCool case as we like!
DeepCool announces a new case intended to welcome our configurations: the CH510. A new model which is declined in white or black with a sober design as we like them… Moreover, the price is not too bad!
CH510: a sober case from DeepCool!
DeepCool CH310In the program, we have the right to a case displaying a medium tower format measuring: 230 (W) x 435 (D) x 471 (H) mm. As for the weight, it shows a small 7.2 kg on the scale, justified by the use of steel, plastic and a tempered glass panel. Internally, there is enough space to accommodate an E-ATX max motherboard. For the fans, there is no need to worry with 170 mm of height available against 380 mm for the graphics card. Finally, the power supply, we have 170 mm of depth available. The ventilation can be consistent with nine slots in 120 mm against five in 140 mm. Despite everything, the compatibility with watercooling radiators stops at 360 mm in front and top. DeepCool CH310 For storage, nothing extravagant with a HDD cage of two 3.5″ slots and one in 2.5″. Otherwise, two more 2.5″ slots are available at the back of the motherboard slot. We finish with the selling prices which are €79.99 in black against €84.99 in white. It’s a pity that the paintwork makes the price go up. Finally, the availability is set for this month of September, just wait until it lands in our shelves.
The DeepCool datasheet is available here !
