CH260 Wood: a small update for the DeepCool case!
DeepCool has made a minor update to its CH260 case. This model, designed for micro-ATX motherboards, now features a wood veneer on the control panel section. This makes the case even more elegant and refined. In short, make way for the CH260 Wood!
CH260 Wood: a welcome wood veneer!
DeepCool CH260 Wood
As a reminder, the case has compact dimensions of 225 (W) x 438 (D) x 312.5 (H) mm. This chassis is designed for micro-ATX and mini-ITX motherboards, while also being compatible with BTF models. There is also space for a CPU cooler measuring up to 174 mm in height. The graphics card has a length of 413/388 mm, depending on whether or not there is a fan on the front. Finally, in terms of power supply, an ATX unit with a maximum length of 15 cm can be installed.
For ventilation, there are six 120 mm slots and two 140 mm slots at the top. Compatibility with water cooling radiators is good, as it will be possible to mount a 360 mm model at the top, for example.
Beyond all that, the case is quite aesthetically pleasing, featuring a mesh grille on the front and top. As for the color, the case is available in black and white and now features a wooden side panel. This small addition will inevitably increase the price, but the question is by how much.
In any case, the case is already listed in China at a price of 449 yuan for the white version and 399 yuan for the black version. After conversion, this gives us prices in euros of approximately €55 and €50. But as you know, in the case of PC cases, a direct conversion does not accurately reflect the final retail price.
