CH260: a new micro-ATX case from DeepCool!
The DeepCool brand continues to expand its catalogue of cases with a new reference. The brand has unveiled its CH260, a reference in the same spirit as the CH160, but just a little bit bigger. Yes, we’re talking about a reference in micro-ATX format here, unlike the 160, which is in mini-ITX format!
CH260: micro-ATX version announced!
DeepCool CH260With this new model, the brand is offering us a reference with a similar design to the CH160, featuring a case with a sober perforated front panel for improved airflow. The same applies to the upper section.
Dimensions are 225 (W) x 438 (D) x 312.5 (H) mm. As for weight, it comes to 3.5 kg. In short, a truly compact case given its format, helped by its internal organisation. Here, the power supply is installed vertically next to the motherboard. This significantly reduces the height of the case.
In short, internally, the CH260 will support two motherboard formats: micro-ATX and mini-ITX, with support for backpannel models. As for the power supply, SFX(L) and ATX formats are also supported. As for the length of the graphics card, it will be able to reach a base length of 388 mm… 413 mm without a front fan. Finally, there’s plenty of room for the CPU fan, and with good reason: an Assassin IV fits inside without too much trouble: 174 mm high.
Finally, the ventilation will not be outdone, with six 120 mm fan slots compared with just two 140 mm slots. In any case, you’ll be able to install a 360 mm watercooling radiator at the top.
Last but not least, the prices are fairly affordable, with a black version selling for $59.99 and a white version for $5 more. As for availability, you’ll have to wait a little longer to see it in stock.
Here are the DeepCool product sheets!
