[CES 2024] CTE E600, Thermaltake also falls for the aquarium case
Thermaltake’s CTE E600 is a new case reference featuring an aquarium-style design with two glass panels for admiring the configuration. It’s in the same vein as the NZXT H6, CH780, etc.
CTE E600: the aquarium case with Thermaltake sauce!
Thermaltake CTE E600With Thermaltake, the least we can say is that the cases are original, especially those from this CTE series. The motherboard tray is oriented at 90°. Moreover, this model can easily accommodate ATX or even E-ATX format references.
As for the graphics card, there are several possible layouts: vertical (via a long riser), suspended or suspended with the fans facing us, anything is possible.
Of course, this series also stands out for the large number of fans it can accommodate. In fact, there’s plenty of room for up to 14 120 mm fans! As for watercooling, it’s compatible with radiators of up to 420 mm, particularly at the bottom or rear of the chassis.
Last but not least, the case comes with several front panels, one in glass for added style. The other will be in perforated steel, to let the case breathe as much as possible.
As for price, the brand’s boutique already lists the case at $179.99, regardless of color: black, white or blue.
Here’s the Thermaltake product sheet!
