Ceres 350 MX: one case, seven colors from Thermaltake!
New cases for Thermaltake who has announced new models for its Ceres series. The brand is now offering its Ceres 350 MX, a medium-tower model available in a total of seven different colours!
Ceres 350 MX: the choice of colour!
Thermaltake Ceres 350 MXWith this case, the brand is announcing a mid-tower model that is compatible with E-ATX motherboards. What’s more, there are additional openings on the tray to make it compatible with Hidden-Connector motherboards from ASUS, MSI and Gigabyte.
Internally, there is space for seven fans, 3x in 120 mm at the top and front and one at the rear. At 140mm, the number of fans that can be fitted drops to five. It also has three 140 mm fans installed by default.
As for watercooling, compatibility with 360mm radiators is assured at the top. At the front, the maximum is 240/280 mm.
As we said, Thermaltake offers a wide range of colours, seven to be precise. The case comes in Hydrangea blue, Snow, Matcha Green, Racing green, Bumblebee, Bubble pink and black. This model also gives users a choice of front panel: glass for added style or honeycombed for improved airflow.
Last but not least, it can be fitted with :
  • A 185 mm CPU cooler
  • 360 mm graphics card
  • 220 mm power supply
Priced at between €110 and €125, it measures 245 (W) x 463 (D) x 475 (H) mm and weighs 8.85 kg.
Click here for the Thermaltake product sheet!
