C4-SFX: an ITX Dan Case ITX that takes big GPU!
A new compact nugget from Dan Case who offers us a C4-SFX case. We are talking about a model capable of accommodating muscular configurations, all in a format of only 14.7l! We are talking about a 280mm AIO support and 3.9 slots graphics card!
C4-SFX: muscular configurations, even in ITX!
Dan Cas C4-SFX
We all know the prejudices about ITX configurations: it’s all tight, it heats up, there’s no room for the graphics card… Lately, things are changing on this subject and Dan Case offers us an ITX case that can do everything.
In this C4-SFX, you will have to opt for a compact power supply in SFX format. Moreover, the graphics card, which is installed at the top, can occupy up to 3.9 slots. The length is very comfortable: 336 mm. Basically, you can put custom RTX 4090s in it, no less.
Otherwise, the CPU cooling part is not left out either. If you want, you can opt for a 145 mm high fume hood or a 280 mm AIO. No reason for the CPU to get hot.
Dan Case C4-SFX
Finally, the case gives access to two 2.5″ slots for storage. As for the cooling, two 120/140 mm fans can be mounted on the CG level as well as in front of the CPU part.
As far as dimensions are concerned, the case is not necessarily THE most compact on the market with its 216 (W) x 398 (D) x 311 (H) mm. But it will be possible to install some powerful configurations.
As for the price, it will cost $235 and will be available on May 11th.
Here is the Dan Case’s page !
