Boreas series: four aircooling fans from Gamdias!
Gamdias announces a new series of aircooling heatsinks. The program includes the Boreas series, a range of four heatsinks. Some are available in white, others in black. In all cases, there appears to be no RGB lighting!
Boreas Series: and four new heat sinks from Gamdias!
Gamdias Boreas M2The first thing to note is that all the heat sinks have the same dimensions. They measure 148 (W) x 73 (D) x 155 (H) mm, and leave a clearance of 38 mm under the fan for the RAM. These are compact models.
Ventilation is provided by a single 120 mm fan, operating from 800 rpm to 1800 rpm. At full speed, airflow is announced at 72.94 CFM, while static pressure rises to 2.63 mmH2O.
Finally, there are two major models: the M2-510 and the E2-410. The main difference between the two is the number of heat pipes. The M2-510 has five, while the E2-410 has four. Note that they come into direct contact with the CPU. Otherwise, the heat sinks share the same design and finish.
Here are the Gamdias product sheets!
