Aurora Rise 140: Alphacool launches its 14 cm fans!
With the launch of the Eisbaer Pro Aurora in 280 mm and 420 mm, Alphacool made 140 mm fans available. The only drawback was that they were not available separately for sale. Now it’s done, as the brand announces its Aurora Rise 140 on the retail circuit!
Aurora Rise 140: Alphacool fans available for sale!
Alphacool Riser Aurora 140In the program, Alphacool serves us RGB with a lighting present on the frame and the central hub. In total, there are no less than 24 aRGB diodes, 16 on the frame and the others on the motor.
Otherwise, we find fans benefiting from a PWM power supply. Their rotation range is between 0 RPM and 2000 RPM. At full speed, the air flow will be 154.1 m3/h and the static pressure will reach 2.20 mmH2O. In short, they have exactly the same characteristics as their counterparts mounted on AIO.
In short, Alphacool is offering its fans for retail sale so that customers can complete their installations. As for the price, you can expect to pay €19.90 per unit. A price that fits in the average of RGB fans in 14 cm!
Here is the Alphacool datasheet!
