During Computex, we had the opportunity to see the Capo X case numerous times at the brand’s booth. Indeed, to say the least, the case was front and center. In any case, it’s worth noting that this is a rather unique model, as it can accommodate up to two complete micro-ATX setups. So, instead of having two cases, you only need one—saving you space!
Capo X: one case, two setups!Â
Micro-ATX compatible and dual 360 mm!
With this case, we’re looking at a model that emphasizes a vertical design. This translates to dimensions of 305 (W) x 448 (D) x 691 (H) mm. As you can see, this model also features a curved side panel, which extends from the side panel all the way to the front.
Inside, the two configurations are stacked one above the other. The case supports micro-ATX motherboards and offers good compatibility for the rest of the components. Specifically, it accommodates graphics cards up to 420 mm in length and power supplies up to 250 mm in length, while the case allows for the installation of two 360 mm water-cooling radiators—one per configuration. As for air-cooling CPU coolers, there is 180 mm of clearance in height.
In terms of cooling, the Capo X can accommodate up to thirteen 120 mm fans. There are three mounting slots at the top and bottom, as well as two more at the rear. The remaining five slots are available on the sides of the motherboards.
Who is it for?Â
The Capo X is ideal for streamers, for example. This way, you can build both a gaming PC and a streamingPC in the same case. It’s also great for gaming couples—instead of having two towers, both machines are housed in a single case. And there are various professional uses as well.
Is it affordable?Â
For now, the Capo X is available in China for 1,270 yuan; however, keep in mind that there are significant differences between prices in China and those in France. We’ll have to wait a little longer to find out the price here in our region.
Check out Thermaltake’s product page here!
