At CES, Cooler Master announces its TD500 Mesh V2 case
Cooler Master, in addition to its peripherals, announces new cases. Among them, we have the TD500 Mesh V2, a model… With a mesh front. Moreover, this V2 comes with a few changes’ here and there, we’ll see what.
TD500 Mesh V2: Cooler Master changes a few things!
Cooler Master TD500 Mesh v2Concerning the dimensions, this model is slightly larger than the V1 with 210 (W) x 499 (D) x 500 (H) mm. On the scale, this model weighs 7.7 kg.
We were talking about some changes, and these are primarily aesthetic. Indeed, we find a slightly reworked front panel, but which still includes polygon effects on its mesh. Internally, the power supply cover now joins the front and we find a removable cover to reveal, in part, its power supply. And that’s without mentioning the design of the various ventilation grids which has been revised.
Internally, we can install motherboards up to E-ATX format. The graphics card, CPU fan and power supply have 410 mm, 165 mm and 200 mm of free space respectively. The storage area features up to five 3.5″/2.5″ slots combined.
Cooler Master TD500 Mesh v2In terms of liquid cooling, the case offers a 280/360 mm radiator support on the front and top. As for the fans, up to seven in 120 mm and four in 140 mm can be installed. Note that now, the top part is removable to facilitate the installation of cooling in the top.
For the moment, no idea of the price. On the other hand, to make a parallel, you should know that the V1 is still traded at around 105 €.
