ASUS: products with the effigy of Demon Slayer
If you like the color of the mini-ITX 2Waybench table and/or if you are a fan of manga, you will surely fall in love with this collaboration between ASUS and Demon Slayer.
ASUS X Demon Slayer
Spotted and shared by @momomo_us on Twitter, you can discover the collaboration between ASUS and Demon Slayer on the JD website. This partnership takes components and peripherals from the TUF range, but also Wi-Fi routers to put them in the effigy of the characters of the manga Demon Slayer.
ASUS X Demon Slayer setupWe note the effort of customization on the headset and the case in the style of Nezuko Kamado with a piece of bamboo well placed in addition to the color change. We also find a router that has the right to a slight physical modification. The RT-AX82U is designed by Hashibira Inosuke and has two small defenses on the front for a questionable style.
ASUS X Demon Slayer routeurLet’s finish on a touch that will be easier to integrate in a configuration with a version of the TUF gaming GT501 case approaching the yellow of Zenitsu Agatsuma as well as a flash at first sight RGB on the front. This variant could be a good alternative for people looking for a yellow case to integrate their components, even if they are not fans of Demon Slayer.
ASUS X Demon Slayer boitier This is only a non-exhaustive list of some of the products resulting from this collaboration, however you can find all the products on the JD website. Unfortunately this type of collaboration is very often limited to the Asian market and therefore has very little chance to arrive in our European setups .
