Asus launches its ROG Loki power supplies, SFX blocks!
Asus launches its ROG Loki power supplies, a series of four models whose power ranges from 750W to 1200W. In addition, we find an ATX 3.0 compliance and the famous 12VHPWR connector. In short, a high quality series as Asus knows how to make them.
ROG Loki, Asus launches its SFX power supplies!
Asus ROG LokiOn the program, four powers announced with models of 750W, 850W, 1000W and 1200W. These should ensure a good performance since the “lowest” powers show a certification 80+ Platinum. The 1200W version is off the beaten track with a very, very large 80+ Titanium certification! This allows an efficiency of at least 90%, even at 10% load!
Internally, Asus again selects quality components with low ESR Japanese capacitors. These capacitors are less prone to power loss and temperature rise. By the way, speaking of temperatures, the brand is again using very large heatsinks internally to improve cooling. Couple all this with a 120mm Axial-Tech type fan for efficient dissipation.
Finally, we will not forget to say that these power supplies are compliant with the ATX 3.0 standard. They are therefore able to output twice their power during a few microseconds. Similarly, they also have a 12VHPWR cable that can deliver 600W of power to power the RTX 40.
As for the price, we know that the 750W, 850W and 1000W models will cost €229.90, €269.90 and €319.90 respectively!
Here are the technical data sheets of Asus!
