ASUS has announced Ryujin III 360 aRGB Extreme!
ASUS has announced a new all-in-one watercooling kit. The latter is none other than the Ryujin III 360 aRGB Extreme, an AIO that benefits from a new Asetek pump: the Emma Gen8 V2, announced as being very high-performance.
Ryujin III 360 aRGB Extreme: new AIO with screen for ASUS!
ASUS ROG Ryujin III 360 aRGB ExtremeAt ASUS, the Ryujin series is the AIO that offers the most functionality. In fact, the kit has a screen on its pump, while underneath, a small fan is responsible for cooling the elements positioned around the socket. Otherwise, as far as ventilation is concerned, the serial connection will limit the number of cables in your installation.
As you can see, the Ryujin III’s screen is impressive, with a diagonal of 3.5″. It will display your .gif files and the elements of your configuration to be monitored in 680×480. It even supports AIDA64 with a special ROG theme.
Ventilation is provided by a trio of 120mm fans. However, they are 30 mm, thicker than the usual 25 mm. Watch out for the speed, which can be very high at 2800 rpm. On the other hand, we have an airflow of 89.73 CFM and a static pressure that we imagine to be high, given the design of the blades.
Finally, the Asetek Emma Gen8 V2 pump should offer a good flow rate and, if possible, lower noise levels than the Ryuo IIIs. What’s more, we’ve learned that it’s “optimised for the hot zones of the Core Ultra 200”.
We don’t yet know the retail price.
Read the ASUS product sheet here!
Here’s our unboxing of the ROG press pack containing the kit
